Just finished replacing the cracked head on my '87 4WD - the old one had gone sudden-like and I drove about 10-15 miles on a nice frothy coolant/oil milkshake before I discovered it. I towed it to my mechanic, who put on a new head, and it sounded great, except for the "creeping idle" stuff that I've read about cropped up. I'm trying to work that out, when I notice a knock that started after it's warmed up. It only knocks starting up in 1st and 2nd from 1800 to 2500 rpm, then it quiets down - even back down to 2k, lugging. I can even drive up a grade and it's quiet, until I come to a stop and then start off again. I though I'd munched a rod bearing, so I dropped the front diff and put in a new set with the engine in the truck- none of them was to the babbit but they were pretty worn. I checked the rear main while I had the pan off and the main looked fine, and plastigaged within new spec, tho it still had the oil film on the engine half so it's not exactly correct, but the bearing looked fine. I didn't check the others after that - anyone who's done bearings with the engine in the truck on their back in the driveway can relate.
Well, I crank her up with my new bearings, and I have better oil pressure, but glory be - I still have the knock. Could it be a wrist pin? those get splash-oiled, and I can't imagine one getting that screwed up for the short time I drove it. of course, I guess the crankcase was getting a nice steam cleaning with that water in there....Any ideas? It doesn't sound like a main to me - not a heavy sound... it just sounds like a rod. I've never heard a bad wrist pin tho.
Also, is it normal for the idle to go up when you take out the dipstick on a running engine? I don't know how the PVC ties in with the computerator...
Thanks
Thanks
