What is this leaking?
Atlanta
This is dripping slowly with AC on. I assume it's just condensation? How worried should I be? It's under passenger side dash.
your drain is probably clogged. Crawl under there (under the passenger side firewall area) locate the drain, and use a pipe cleaner or other tool to clean out the drain
You could also remove glove box and remove that cover to get a sneak peak inside. Mine was loaded with debris but luckily the drain didn't clog.
If you pop the hood and look in from the passenger side. Look up against the fire wall by the swirly brake lines. Right below that closer to the engine is a rubber tube. That is where water should be going.
Info on cove removal
A/C condenser drain leak - https://forum.ih8mud.com/threads/a-c-condenser-drain-leak.935544/>
Here is the extension kit so once you fix leak you can extend the drain to drip not on your sway bar bolts
100-Series / LX470 / GX470 AC Drain Extension Kit — CRUISER GARAGE - https://cruisergarage.com/products/ac-drain-extension-kit>>
