What have you done to your Land Cruiser this week?
It was a good weekend. I removed the old black paint from the transfer case and cleaned it up best I could. I found a small repair was done at some point using JB Weld(?). Gotta love these Costa Ricans. She's got a few battle scars but she's been a very dependable. I also had to adjust the headlights because they looked like Marty Feldman's eyes. After a quick inspection I noticed they weren't a match, so I ordered a new set of Sylvanias. Will install them when they arrive later this week. I'm replacing the plastic green fuel cap with a nice shiny one made of metal. It's also on the way. What can I say, I'm an old school sumbish.
I'm also going to remove the AVM locking hubs (barely a 100 miles on them) and replace them with a nice set Warn hubs that I purchased a few months ago. Those things are extra beefy.!! It's going to be a productive week.
Just a few more thing left on the to-do list. .. (yeah right!)
absolutely gorgeous 40.
Never underestimate the power of JB weld!
New exhaust now in place. Now on to fixing that lean!
The lean is a character trait. Some say it can’t be fixed.
I have an invoice from 1977 where the driver side spring pack was replaced due to being “deformed” at 1408 miles and leaning and 47 years later it’s starting to lean again. 😂 like you said I think it’s part of owning a 40.
I too have seen several FJ40’s over the years with a sagging side. I have never had this on mine but what is going to be the fix? Is it only a spring issue?
Can you go to a spring shop and request an “X” amount of re-arcing to add more lift the the affected side?
CCOT sells a “Leveler Block” that’s basically a shim that sits on top of the spring pack. Spring replacement/replacing the bushings is also an option but can get pricey. I’m gonna try replacing the bushings with this Spring bushing kit and see if there is any improvement.
It's called "cruiser lean". I'm surprised the dealer didn't install the leveling block.
… and charge you a grand
The leveling block is installed on the high side to lower it.
You just wanted to use “hardened” and “nipples” in the same sentence. Well played I admit, but this is a public forum hombre..😁
@65swb45
@Voodoocruisers
@Spike Strip
@wngrog @cruiseroutfit
There is a new OEM genuine NipponDenso japan. spec. cooling system SNOW VERSION option sheriff in town .......
She sports the most millimeters of any OEM FJ / BJ / HJ 40 / 55 series overflow bottle ever offered as standard feature or a ( OPT ) cold spec. / heavy duty package by Toyota ...
Uses the same OEM radiator drop-down bracket , we now
proudly reproduce using our NOS OEM specimens we did originally offer years ago with it;s shorter Genuine NipponDenso sister we still also offer too ....
- all our cooling system bottles now have my concept vision of a
180' degree-view twin-dueling OEM yellow caution decals we reproduce in-house and hand apply heat press vinyl
. thanks for your support
Installed the Downey tank I got from Mark last week. Also painted and installed the new steering column. My original wheel is completely jacked and cracking worse than before I repaired it last time so it’s being replaced with one from a ‘53 chevy truck Speedway sells. Diameter is 15” to go with the Saginaw power steering I will install. Still waiting on engine mounts from Advanced Adapters.
Went to dinner at the fancy sushi place with some high dollar friends who were in town. Amazingly, the 20 something valet drove a stick as his daily.
Got the showpiece parking…
Valet said it got more attention than any car since he’s been working there. I threw him a $20 for not burning my clutch to the ground.
Fabricated custom bracelets to mount a 2003-2006 Tj bench seat.
Painted the hinges and frame since they were raw metal.
Paint job wasn’t perfect but it’ll never see the light of day again.
When tumbled forward it just touches the back of the driver’s seat. The seat lifts out with a pull of a lever. It’s about the best fitting bench seat I’ve seen… short of a custom seat made from scratch.
In progress picture but it shows the space well. Brackets weren’t installed yet.
upholstery came off easily so I painted the raw metal.
The seat is spring loaded so it should stay tipped forward.
In progress while fabricating the brackets.
