What happen (8 Viewers)
Fallon,NV
Wow its way to quite in here what none doing anything worth letting the rest of us in on or what hehe
Dan :cheers::steer::bounce::bounce2:
Top SECRET activities.
Were being WATCHED you know.:eek:
Well,
I could tell you all about replacing the front output bearing on the transfer case of the 80, dropping the case as I was removing it, buggering up a flange stud and breaking a $190.00 sensor in the process:doh:. Not being able to find a die for the stud (11mmX 1 thread pitch), filing it back into shape, blowing a lower extremity getting t-case remounted, not being able to finish because the $190 sensor is located on top of the t-case, so until I can get one (looking for one used now) the t-case is being supported by straps, the drivelines are still out, the skid plate is lying on the floor.
So yeah, I had a great weekend. :flipoff2:
That's what I have been up to.
Jack
Jack you have all the fun. If you ever need help call me only live 10 - 15 min. away wouldn't want you to hurt your self.
Don't I know it. It's probably because I don't forward chain emails:hillbilly:
I forget that you live that close, I appreciate the offer, I just might have to take you up on that the next time I think I can lift heavy things...
Jack
Well sorry to hear about the 80 Jack but at least there is some activity on here now Lol and i already have AFBD i keep it handy for those times when i really need it wich is whenever im Home ROFL but all my walls have foil in them so im pretty well set gotta love that dollar store real cheap way to make that happen hehe anyway good to see somethin going on might not be fun but atleast theres a new topic Yea
Guess I could tell you about my move, changing jobs for the wife and I, and all the drama. But that would be just like real life. I come here for entertainment.... That's why I like Jack..
Wheeling and wrenching are for people who have time to live life, rather than just ride the wave and hope for a sandy beach and a soft landing, rather than the breakers and rocks like what usually happens.
Running out of things to remove from the 55. Gas tank on the floor by this weekend. I've got an engine at a friends house, a NV4500 being built in the north valleys, and the fun part of a 203 in my dad's garage down in california. Probably should order the adapter soon. PS box from a 60 sitting on my floor. Sorting out how I want to rebuild the rockers and body mounts now. Too bad I don't know what's practical and what isn't. Keith, I may need to drag you down here to advise...
slow progress.
Hummm. As long as we are sharing.
I've been battling the DS window on the 100. Toyota wants you to buy a $250 window if you break the $5 plastic tab that attaches it to the regulator. Found a used set at Crusier Solutions for $20, got them and they still had all the glass and RTV in them, spent 2 hrs figuring out how to clean them up with out destroying them, destroyed one in the process, then replaced the broken one, let the glue set for a couple of days before I tested the window action only to find out the jam switch needs to be re calibrated, found a website that had the FSM in PDF as a free download so I'll be trying that tonight.
In comparison the 40 is moving along pretty well except that I spent a couple of hours trying to figure out how to get the Longfields apart so I could clean out the grease and oil slurry in them, turns out the answer was a bigger hammer. I ran the procedure for aligning the birfs with the SST and have the "correct" shim thicknesses, so the front axle should go back together this week, I figure can do one side a night, then all I have to do is pull the front springs and add a leaf or two back in and the 40 will be ready to go except for the anti wrap bar.
I'm afraid to start anything on the 60:eek:, but it needs a pan gasket and seals or hoses or something in the PS pump.
And the doctor says I need another operation on my wrist:mad: maybe I should have listened about the weight restrictions:confused:
OTOH I still have a job, a house, and a family so I'm doing better than a lot of other folks.
Thanks for sharing everone, now I don't feel so bad. Seems like everyone's projects are putting up the good fight.
RustyDan, are using Marlin's new seals in the front axle of the 40?
Jack
Jack
Yeah, I got the whole knuckle service kit with the uber tuff seals from Marlin. I'd like to go for a long time with no oil puke on the knuckles.
The good news is if anybody needs a hand with a knuckle service I pretty much have the procedure memorized.
BTW I hope you didn't undo the surgery you had this winter.
Good deal on the front axle. I am the point where I am debating on whether I want to go with Toy axles on Drippy. I really hate the greasy mess that is Toy front axles. I have both the stock axle and a complete '84 front mini axle, so I have two to choose from/build, but I just don't know if I want to put the money into them. I might go dana. I might be able to score a built d44 with gears/arb, etc. from a buddy or I just might go all the way and do a 60 front. Depends on whether I can find a deal or not.;)
Me too. I think I am pretty good, I have a bionic lower abdomen now, it's all fiber/mesh re-inforced. ;p
Jack
Jack
Wouldn't the D44 be a downgrade in terms of strength?
WOW Jack, that is a bummer man.Which LE did you injure in that task? Hope its nothing serious, like your BACK that had in turn impacted your legs? That would be a BAD thing.Well, for me, the kids are now gone. We have a house again and I have my garage back and a pile of work to do in it...Couple of weeks ago I went to fire up the lawn mower, and the first pull broke the rip cord. For some reason I couldnt get it back to gether to were it worked right, so I took it to a small engine friends house to look at...well, he got it back together, fired it up and it turns out that the shaft is BENT and is essentially toast. Then I remebered that the chillens stuck a nice BIG ass rock out in the middle of the grass that I didnt see and of course HIT. F*$& MOTHER F*#$%R G@wD@*N SON OF A B$*%&!!!!!AAAAAND now since we have our house back, all of the repairs are to come which includes paint, faucets, slider screens, re do my "OFFICE" (the shatter) and some curbing and some landscaping. CHA CHING, CHA CHING, CHA CHING!I might have to put Rusty TLC's engineering skills to work soon on a wiring harness.However...much like Rusty...I have a good STABLE job, a wonderful wife that puts up with my SH$T and good health for us and the family.K
Next .....
Good to see everyone is being kept honest . Looks like Im par for the course here , trying to strip, repair, prep and epoxy the garage floor (its 60+ yrs old ) Oyeah I got a plasma cutter!:cool::cool: Been trying to do side jobs to keep in the game. My next project is a aluminum skid plate fo a buddies Cobra:grinpimp:
Looking forward to the next run , hoping to do Barney Riley soon.
ken
Hey Fellas...hope you don't mind if I share too. Sorry to hear about your debacle Jack, I'm feeling ya. I've had frustration lately with my 40. It runs good with the TBI going now, in fact it runs like a whipped dog. I love driving it, even if the steering is sloppy as hell! I decided several weeks back that I ought to finally get the thing registered and street legal - you know I've owned it for a long time and gotten to drive it very little. Anyway, got a temp moving permit from DMV and took it for emissions test. Guy lifted the hood and said, "Uhhhh......uhhhhhhhh.......you got a special letter for that engine?" (that's an actual quote ;)). My reply, "Uhhhh......"
I have since learned that I need a letter from DMV for the engine swap (chevy 350 by previous owner) before anyone will even test it. The process with the DMV was more than I care to re-tell here, but eventually I scored the letter and they even agreed to smog it to '68 standards rather than '86 standards which would have really set me back. So, with letter in hand and hope in my heart, back to the emission place I went. And failed. :crybaby: To make an already long story short, I have tested it now 3 times and failed. The last test was close. I had reconnected the EGR, installed a the charcoal cannister and installed a PCV valve as well as fixed a couple exhaust leaks. It's funny...with computer controlled fuel injection I thought smog would be a breeze. My carbon monoxide is too high now...everything else is in range. Seriously stumped and frustrated. 'Bout ready to just tear it down and start the frame-off I've been fantasizing about for so long....oh wait, I'll need a small fortune to pull that off :bang:. With that said I will echo others comments, at least I've got a decent job and my family is happy and healthy...all the rest is just gravy after that. :cheers:
Ed
Well,
Jack
and to think I didn't make any plans this last weekend.... and my house is walking distance from yours :grinpimp:
It may not be for long though! ;)
Ed
I guess I'd better try to preserve the california BAR sticker on mine...I think that's why they never gave me any trouble over the 71 vintage 350. I really wanted to repaint that door...
