Found this tire googling to be 121/118 S
Is maxload for single load axle 1450kg/ 3197 lbs maxload AT 65 psi, upto 160kmph/99mph.
Check that especially the AT65 psi, but E-load in this wide size has not 80 psi, but 65 psi referencepressure, to my knowledge.
Then the 25 psi I estimated would cover a good 2400 lbs axleload.
For this I made list with that build in reserve, so now you "ONLY" have to determine the axleloads 99% acurate, the most tricky part and your responcibility.
For max speed 160kmph/99mph onroad, and with that build in max reserve, but still acceptable comfort and gripp.
So you dont need to do pre- or after-calculations yourselfes.
Axleload lbs/ cold psi/ Axleload kg
2072 lbs/ 21,0 psi / 939 kg
2158 lbs/ 22,0 psi / 979 kg
2244 lbs/ 23,0 psi / 1018 kg
2330 lbs/ 24,0 psi / 1057 kg
2416 lbs/ 25,0 psi / 1096 kg
2502 lbs/ 26,0 psi / 1134 kg
2587 lbs/ 27,0 psi / 1173 kg
2673 lbs/ 28,0 psi / 1212 kg
2758 lbs/ 29,0 psi / 1251 kg
2843 lbs/ 30,0 psi / 1289 kg
2928 lbs/ 31,0 psi / 1328 kg
3013 lbs/ 32,0 psi / 1366 kg
3097 lbs/ 33,0 psi / 1405 kg
3182 lbs/ 34,0 psi / 1443 kg
3266 lbs/ 35,0 psi / 1481 kg
3351 lbs/ 36,0 psi / 1519 kg
3435 lbs/ 37,0 psi / 1558 kg
3519 lbs/ 38,0 psi / 1596 kg
3603 lbs/ 39,0 psi / 1634 kg
3687 lbs/ 40,0 psi / 1672 kg
3770 lbs/ 41,0 psi / 1710 kg
3854 lbs/ 42,0 psi / 1748 kg
3938 lbs/ 43,0 psi / 1786 kg
4021 lbs/ 44,0 psi / 1823 kg
4104 lbs/ 45,0 psi / 1861 kg
4188 lbs/ 46,0 psi / 1899 kg
4271 lbs/ 47,0 psi / 1937 kg
4354 lbs/ 48,0 psi / 1974 kg
4437 lbs/ 49,0 psi / 2012 kg
4520 lbs/ 50,0 psi / 2050 kg
4603 lbs/ 51,0 psi / 2087 kg
4685 lbs/ 52,0 psi / 2125 kg
4768 lbs/ 53,0 psi / 2162 kg
4851 lbs/ 54,0 psi / 2200 kg
4933 lbs/ 55,0 psi / 2237 kg
5015 lbs/ 56,0 psi / 2274 kg
5098 lbs/ 57,0 psi / 2312 kg
5180 lbs/ 58,0 psi / 2349 kg
5262 lbs/ 59,0 psi / 2386 kg
5344 lbs/ 60,0 psi / 2424 kg
5426 lbs/ 61,0 psi / 2461 kg
5508 lbs/ 62,0 psi / 2498 kg
5590 lbs/ 63,0 psi / 2535 kg
5672 lbs/ 64,0 psi / 2572 kg
5754 lbs/ 65,0 psi / 2610 kg/referencepress
5836 lbs/ 66,0 psi / 2647 kg
5918 lbs/ 67,0 psi / 2684 kg
5999 lbs/ 68,0 psi / 2721 kg
6081 lbs/ 69,0 psi / 2758 kg
6162 lbs/ 70,0 psi / 2795 kg
6244 lbs/ 71,0 psi / 2832 kg
6325 lbs/ 72,0 psi / 2868 kg
6406 lbs/ 73,0 psi / 2905 kg
6488 lbs/ 74,0 psi / 2942 kg
6569 lbs/ 75,0 psi / 2979 kg
6650 lbs/ 76,0 psi / 3016 kg
