I have been struggling with the rear exhaust manifold. I attempted to extract the studs that connect the rear manifold to the down pipes, but one stud kept breaking off. I finally gave up after welding nuts on, applying, heat, going forward and backwards, letting it soak in Kroil. I took it to the machine shop that rebuilt my head, and they had it for a week, and they could not get it to turn out either. Finally, I took it to a local Cruiser only shop and he thought he could get it, but only got it to move slightly then it seized back up. In frustration, I ordered a set for the 95-97 80’s from my local dealer knowing that I had already removed the pair valve, but really wanted to put the O2 sensors in place of the Pair valve, and put the plates over the bungs in the exhaust or just leave the old O2 sensors in place. Then I realized that
@Fj80oregon might have what I needed, and as per usual, he came to the rescue, and is sending me the rear exhaust manifold I need with the bung in the manifold!
Tonight I was able to de-pin the broken transmission speed sensor plug that broke during the engine/transmission installation and replace it with a connector sourced from my local dealer. I also got the front and rear drive shafts re-installed. Leave it to me to be the idiot that loses the stupid brass clip that holds the transfer case shifter to the transfer case. Luckily you can still get them from Toyota, so I got that installed as well. I know once I have this truck back on the road, the little baggie with the dang clip will turn up, but I can’t wait for it to turn up on its own. I also fixed my mistake where I installed the power steering cooler upside down, and put on the Moly panel on the back of the center console. I plan to install my GMRS radio here since I will not have any of the seats in the rear.
