picked up a facebook marketplace 3 point hitch log splitter that i will adapt to a skid steer. yay win.
Love the pods and the great looking cards! Where did you pick up the pods and cards?Finished new speaker installation after headunit upgrade
Swapped these poor guys (left) for a set of Focal Flax Evos
Made some brackets to mount the crossovers inside the standard speaker door opening
Used these Aussie made door speaker pods from Stealthtech, really nice quality and leather matches up perfectly with the door cards. Also added the factory courtesy lights to them
Used the tweeter mounts from Solvefunction, cool product with good fitment both for the tweeter and install / cable routing
Door with the new pods /speakers finally assembled
Really amazed how nice the system sounds already with them just running off the headunit, want to add an amplifier later if I can find the right sized amp for a good hidden installation somewhere behind the dashboard.
I don't mean this rudely, but what's the point of that?
COS80, in case there's an emergency where someone could be getting hurt, it's good to be able to kill the power to the winch; a safety precaution. It also reduces the chance of a drain of my only battery.I don't mean this rudely, but what's the point of that?
You run a which with your hood open ? If things went so south so fast I would want something like that right next to the winch so I wouldnt have to run to the cab to pop the hood then run back open the hood to shut it down . On a different note you might want to put something on that coolant hose before you wear a hole in it .COS80, in case there's an emergency where someone could be getting hurt, it's good to be able to kill the power to the winch; a safety precaution. It also reduces the chance of a drain of my only battery.
Those were the things that compelled me to install it.
Your doing it right with new/good parts and at the rate you’re going you will on the trail long before @baldilocksWhen you spend this much time and money preserving a piece of history, it only makes sense to take care of it with good fluids! I also have OEM red coolant and OEM transmission fluid to in as well. I thought the pump bottle I was getting was a little bigger but it got the job done.
Damn, how many ya got?!
I will stop when my wife finds out I have a storageDamn, how many ya got?!
I put one under the hood too...I figured that a big a$$ positive cable coming straight from the battery down to the front bumper could be a real hazard in a front end incident, either on the road or trail. I've found that with my wheeling and the habits of my trail friends is that I usually know if it's a good time to pop the hood and flip that switch before I get into a hairy situation where it may be needed. That said, there is no perfect solution, but just hoping to make mine a little safer where possible. I did do some research on running a hefty fuse/breaker in line in case of a short, but from what I found at the time, the shutoff switch seemed like the best option between the 2.COS80, in case there's an emergency where someone could be getting hurt, it's good to be able to kill the power to the winch; a safety precaution. It also reduces the chance of a drain of my only battery.
This! A high amperage fuse/circuit breaker/switch is recommended for all winch installations but most people don't install one. You did the right thing.I put one under the hood too...I figured that a big a$$ positive cable coming straight from the battery down to the front bumper could be a real hazard in a front end incident, either on the road or trail. I've found that with my wheeling and the habits of my trail friends is that I usually know if it's a good time to pop the hood and flip that switch before I get into a hairy situation where it may be needed. That said, there is no perfect solution, but just hoping to make mine a little safer where possible. I did do some research on running a hefty fuse/breaker in line in case of a short, but from what I found at the time, the shutoff switch seemed like the best option between the 2.
God bless America for the abundance of turkeys and the our landcruisers. Man what you are doing is so cool, makes me want to get into hunting. I fish salmon over here in the Washington State.Picked up a couple more freeloaders who wanted to ride in the 80. They paid a heavy price…
I'm certain they fought valiantly...Picked up a couple more freeloaders who wanted to ride in the 80. They paid a heavy price…
