Well,We have identical trucks and we're doing identical things.
we need a picture to prove it
Soon.Well,
we need a picture to prove it![]()
I used a pry bar to move it into position. Try that. And if you need help let us know. There are a lot of us in the seattle area.View attachment 3844859
s***ty pic,
But the bolt from the stock panhard location is in
The bolt the goes true the bracket and rear up arm is half way in, but coming out it is not lining up, the bracket hole and rear upper bracket hole ate aligning, but the bolt coming out of the bushing is not.
I tried using a ratchet strap to bring the axle back, forward and sideways and nothing seams to work![]()
I don't have this.Depends, this is the correction I have and it plugs into the TC
Lutz Auto - Speedometer Correction Device
We are pleased to bring you the fully plug-and-play Lutz Auto Speedometer Calibrator for 80/100 series landcruiser's/LX's. This speedometer calibrator is fully adjustable and has no latency issues. After installing and calibrating it, you will forget that it exists! Ships quickly from the...forum.ih8mud.com
Thanks!!I used a pry bar to move it into position. Try that. And if you need help let us know. There are a lot of us in the seattle area.
@Broski suggestion is great too. A strap might move into position
I use this in all rigs....cheap $. Plug N playToday I discovered that my LX has the speedo corrected, somehow. I've been blocking traffic for two years, thinking the speedo was off by 7%!!
So what do I look for? Is there some kind of electronic doohickey or an old-fashioned gear?
I definitely don't have that. The actual speedo is reading equal to GPS with 295s.I use this in all rigs....cheap $. Plug N play
Universal Vehicle Smart HUD... https://www.amazon.com/dp/B07HNDLGPC?tag=ihco-20
Thanks! Yes, swapped directly on. It was a 10-15 on. It came with the back trim, cruise switch, horn switch parts. I was planning on swapping mine over but the cruise switch on this looked/felt brand new so I left it. Everything plugged right in and works like it should.Direct swap from what year? Looks good!
Two good looking rigs. Tell me more about the pew pew.-Adjusted my parking brake(installed new rotors recently but didn’t have time to properly setup p-brake then).
-removed both front door cards to check funny operation of passenger window and tighten loose outside door handle on driver side. Found broken glass in driver door and very poorly wired speaker. Also found missing bolt in the bottom of the door that was causing loose handle and put it back. Found severed wire to speaker in passenger door and repaired it. Hadn’t even noticed speaker wasn’t working,lol. Found a few of the bolts for the window mechanism loose and tightened them.
The more I dig into this 80 the more suspect stuff I find…not sure if it’s age related or prior damage that has been repaired. Either way, this thing will keep me busy whether I want to have projects or not! Haha
Oh, and a couple of pics from target practice recently with the 80 watching
Check that the screws they provide clear your flange mine did not, I have thread of the screws you need.View attachment 3845215
Got the Trail-Gear spindle locking nuts on. I'm not sold on them. Required some filing of the top nub on the locking ring. They'll work just fine however.
16” .223 built with Seekins billet upper/lower, rock creek barrel, geiselle trigger. Nightforce 1-8x on top. Thunderbeast 30P-1 can on the end. It’s my favorite all around gun. I was shooting a 240yd target and a 455yd target that day.Two good looking rigs. Tell me more about the pew pew.
Sounds like a great build. I am actually thinking of swapping out one of my 556 barrels on one of my SBRs to a 12.5 6mm ARC barrel from Noveske. Noveske has a new gun coming out with at 12.5 6mm ARC that they have taken out to 1K yards.16” .223 built with Seekins billet upper/lower, rock creek barrel, geiselle trigger. Nightforce 1-8x on top. Thunderbeast 30P-1 can on the end. It’s my favorite all around gun. I was shooting a 240yd target and a 455yd target that day.
Thanks for the heads up. Believe they've been sending the new pan head screws for quite some time now. Mine were, at least.Check that the screws they provide clear your flange mine did not, I have thread of the screws you need.
