Thanks for the advice. So was planning on just dropping the head of do they need the cams also?
You will want to put all the buckets back in place and install the camshafts loosely with their caps. If you tighten them more than just a couple threads, you will want to follow the cam torque sequence. The machine shop needs valvetrain parts to get the valve adjustment correct after their machine work is done. That does not mean you can just slap everything back together; instead be sure to check the valve adjustment when it is all back together.
