I got shipping Notification on my new rear shocks and am checking on a set of springs for out back to match. Hoping to do the Tacoma hub swap while I have the front apart to put the coilovers on.
I have a few left over. I am going to wire one up as a toggle switch inside the engine bay for when I am working there, and use another on the rear hatch, near the bottom of the door to use when loading and unloading cargo.
Wow, a couple of those lights under the hood would be amazing.
I notice they have a new version of the lights that are a bit brighter. I wonder if they would be too bright? How do you feel about the brightness of yours? Bright enough?
Yeah I need to get off my ARSE and get mine mounted. They have been sitting on my bench for 2 years now. Gonna try and use a couple for lights under my awning.So boredom ensued, and today I got my rock lights installed. I got them from a place called www.under-glow.com and got a great deal. Each light is a 4 pod LED on a flat surface so it is very low profile. It is coated in a waterproof sealant and disperses a great amount of light.
Very simple process. 2 wires in, 2 wires out. Adhesive tape on the back that is CRAZY strong. I messed up one of the lights and had to use a screwdriver and a hammer to get it off.
These things come in a set of 20 for $25, and for that price, I couldn't say no.
I have 1 on the front body mounts on either side, one in the front, one on either side of the crossmember, 1 on each body mount on the sides of the frames, 1 on the frame on each side, one on each rear body mount, and one directly above the rear axle.
Onto the pics.
If you'd like more info give them a shout. www.under-glow.com. Also, they have different colors if you'd like to go a little crazy with it. Great customer service and I got mine in less than a week after ordering.
Ordered a few small parts today. Valve cover gasket, hub gaskets, rear pinion seal, thermostat, oil drain plug gasket.
Rear pinion was leaking. Don't want to sling oil all over the place.
Thermostat is questionable. But most likely toast.
Hub gaskets are non-existent.
Need to pull valve cover and check tolerances.
I need to go ahead and get a knuckle kit for when I start front axle clean up.
SWEEEEET!!!
