I puttered about and didn't really do what I wanted. I started out fixing why my lightswitch didn't turn on the lowbeams. Highbeams worked fine. so I took the switch apart and cleaned it up and shined the contacts like I should and put it back together and it worked.
Now, for a long time, I've had the headlights come on with the first click on pulling the switch out. I know that the running lights should come on with the first click and the headlights come on with the second click. Mine didn't. I might've swapped in a different switch in years past, I forget. Maybe it's a 40 switch, maybe a slightly different year 55. I bet if I studied and compared and contrasted schematics from different years and models it would be obvious, I'm getting right on that.
It worked so I figured I'd just button it up, then got the crazy idea of getting rid of the extra wires running down that inner fender. So I did, the cutoff remnants from the smog computer, the alt and voltage regulator from when they were on that side. I unwrapped the engine side of the harness, pulled out the unneeded stuff. I'm pretty sure I know what I don't need, mostly wires that I cut 25 years ago. So I put the fancy new loom on the remaining wires and the fancy OEM wire hold-downs from @CruiserTrash that I am liking more and more and thinking that I should do more of this electrical stuff and then tried the lightswitch and my lowbeams don't work. So, polishing turds, not fixing problem.
