What about Bob? (1 Viewer)
Thats what you get for slackin', lorena's not "easy" so she cut your birfs off.
Are your springs bolted (hard mounted) to their mounts or do they just drop out on a regular basis?
thats some flex!
when you losing the doors?
thats some flex!
it ended up being a hard line because my driver tire would NOT stay on the rock... kept sliding off...
I used metal cable tie to secure the springs to the bottom perches... $5 and I still have an entire roll!
And yes, they come WAAAY off the top...
loosing the doors once I ino/exo the dirty girl. Until then, it's about my only structure.
the rest of the obstacle
and a childhood friend that I hadn't seen in over 20 years until yesterday..., same obstacle:
It was the second run that made the popS
Lenny, I walked it the first time... went back later in the day... under direction from a few, I tried an "easier" line on the first large rock.... pop-pop!
BobIt calls
"If you turn the wheel into the rock it'll grab... I mean the wheel'll grab"
Just trying to help a brotha out. Haha
you're brotha brock? I coulodn't hear you over the turkeys. You musta been trying to send it through ESPn or something.
from yesterday's teardown of the front axle... alot more measuring than wrenching... all the chiefs...
The button-up should start back today...
Yeah, and 3 others actually showed up a little later... it was an all out G8 summit with all the leaders sitting around watching me turn wrenches!
did you protest?
that knuckle arm in the pic looks as big as a bat. can use it against the naysayers
