- Year
- 1996
- Vehicle Model
- 80 Series
- Mileage
- 338777
- Color
- White
Preliminary asking price: $ 15,500
Actual selling price: To be determined
Better / more photos to be uploaded soon.......
Acquired from previous owner on 5/23/2011 with 213,900 miles
VIN: JT3HJ85J2T0126403
Items that may need attention:
Needs detailing - clean the carpet and polish the exterior
Check engine light for ABS - (intermittent) and airbag light on. I have not checked the codes yet.
Shaky driver side mirror needs new zip-tie
Head gasket has not been replaced - but vehicle has never run hot
Windshield - has crack but passes state inspection. But it needs replacing…..
Power steering groans when cold
Steering wheel shows its age
Driver side exterior door handle is broken. Functional, but needs replacing.
Rear spoiler removed. Small rust spots at original screw holes.
Trip odometer does not work
Dent in left rear pillar from previous owner. Some rust showing at edge of dent
Other Items:
Has ARB front bumper but signal light is not wired up
Has roof rack
Has trailer hitch
Slee headlight harness and HIR headlight bulbs
Front seats replaced with Shane MetricTLC leather kit
Landtank seat extension installed on driver seat
I removed the interior wood grain stuff
There are no third row seats
There are no lockers
Tires: BFG KO2’s, 265/75/16 with 18,000 miles on them and they are VERY STRONG
Maintenance Outline
335,318 3/28/23
Larry's: replace front brake pads with OEM 100's OFCI
replace rear brake pads with other as 100's would not fit per Danny
bleed brake lines
335,259 2/13/23
Larry’s auto shop
replaced alternator OEM furnished by owner
changed oil and filter furnished by owner
335,000 2/1/23
New battery under warranty from autozone
Mileage: 6/22/22
Larry’s auto shop
Replaced 3 belts.
326,258 1/5/21
Larry's Auto Shop
replaced owner furnished starter (OEM)
replaced owner furnished fuel filter (OEM)
replaced front and rear diff grease 80/90 synthetic, 6 qts total
325,862 10/24/20
New battery. Duralast Gold at least 710 CCA from Autozone
325,800 10/23/20
Replaced brake booster and master cylinder
Toyota Techs: Johnny and Mark
Johnny said brake lines were good
323,000 11/22/2019
replace failed power steering hose under reservoir (5/8" diam htr hose)
added Dexron II trans fluid and bled system by jacking up front axle under front diff, blocked wheels and turned steering wheel lock to lock three times with engine off.
Topped off reservoir.
Lowered front end and turned steering wheel lock to lock three times with engine on.
System bled and ok
320,497 5/7/2019
BFG KO2’s
265/75/16
Aligned front end
317,000 6/5/16
New battery
309,050 9/10/2015
Replaced bushings on front sway bar
306,901 7/24/15
Remove and replaced steering stabilizer
300,586 4/14/2015
Replaced rear brake pads with Carquest pads
295,000 1/10/2015
Rebuilt power steering pump with CRUISER DAN kit
Replaced hi pressure hose with NAPAa gates
Replaced three other hoses with OEM and generic NAPA
New ATF in power steering reservoir
292,734 10/14/14
New 285/75/16 Geolandar A/T-S Tires - Tire Kingdom
292,547 10/10/14
Installed new window run on Driver Side window
Installed new Bosal muffler from partsgeek.com with hangers from Toyota
OEM gaskets included, new gasket on O2 sensor, no codes
291,350 9/24/14
Replaced shocks with OEM Toyota. Torqued all bolts to spec.
291,002 9/12/14
Checked torque on hub studs 26 ft-lb-good
Inspected all brake pads. Good.
Removed and replaced (4) tie rod ends. Torqued to specs
Adjusted toe-in to 1/8" at 36" distance
Adjusted bump stops
Adjusted drag link (relay rod)
Looking in cross section from DS, rotate relay rod counter clockwise to move steering wheel counter clockwise. Rotated tires, cris-cross
Cleaned front rotors
290,812 9/8/14
Inspected birf grease-good
Inspected knuckle bolts - good
289,000 8/6/14
Replaced AC condensor and clutch with DENSO by Mark and Johnny at Toyota Tech $775.00
Reworked oil sensor wires, Mark may have knocked them loose.....
Replaced 2 OEM PCV hoses at Mark's recommendation
281,000 2/2/14
Passenger side Knuckle rework due to lost stud and 1 sheared knuckle stud
Tore down knuckle
New axle seal
New top and bottom trunion bearings w/new races
New out wheel bearing
Did not replace inner wheel bearing, still "new" from last summer
Cleaned birf. Grease looked good from last summer
Put back together, new knuckle studs with "star" head from Beno. Used blue loc-tite.
2 tubes moly
279,000 1/1/14
Lubed drive shaft, except for very rear
265,100 7/5/13
replaced charcoal cannister
misc small hoses
264,800 6/29/13
Replaced belts
Replaced upper idler pulley
Replaced front main crank seal
300# torque
Replaced oil pump cover gasket and 7 screws
replaced dizzy o-ring
replaced dizzy dust gasket
replaced fan clutch
255,100 6/10/13
Front axle rebuilt kit from Cdan
Swapped birfs side to side
256,000
Replaced knock sensor using 27 mm deep socket
Flushed Radiator, installed new OEM big hoses 3 large and one small from CDAN
Refilled with 2 gal Carquest green low Silicates coolant and 2 gal distilled water
255,000
R&R Plugs/Plug Wires
Belkin wires from NAPA
Installed Used Tranny with 126k miles from LX450 (Buster's did the install)
New Radiator / Green Univ Coolant
255,000 2/1/13
R&R cylinder #5 plug - misfire code
255,000 1/31/13
Replaced hoses and PHH by Toyota Tech, Mark and Johnny (125.00 labor)
Flushed Radiator fluid, refilled with 1 gal Toyota Red & 2 gals distilled
249,500 11/03/12
drained AT
replaced filter & gasket (NAPA)
replaced AT pan (spun bun)
replaced AT wire on solenoids in pan
checked all solenoids, Good
one pan bolt not seating
(passenger side, rear corner)
249,000 10/28/12
exchanged AT fluid
246,000 9/17/12
Installed Slee headlight harness and HIR headlight bulbs (4)
Changed front diff, rear diff, xfer case. Xfer case and rear diff were perfect. Lubed u joints. Filled knuckles
242,000 7/29/12
Rotated tires front to back
Added grease to driver knuckle
Grease gun has red knuckle grease in it About 75% full
14 mm box wrench fits square knuckle fill plug.
237,000 5/5/12
Oil / filter change, Lubed drive shafts
234,000 3/10/12
Changed trans fluid (Replaced washer)
Flushed coolant again (25%AF)
Replaced belts (OEM)
Replaced water pump - OEM
Replaced spark plugs & PCV valve
233,500 3/1/12
Flush radiator
Changed trans fluid / Changed air filter
229,000 12/11/11
Lubed drive shaft 4 places
Pulled pan- changed trans filter and changed trans fluid
Changed fluid in diffs and xfer case
Replaced starter
Checked NSS
218,700 7/8/11
New battery
Oil and filter change summary
5w30 ext perf Mobile1 syn 7.8 qts with M301 filter
335,259 2/13/23 Mobile 1 with Mobil 1 filter
329,550 09/03/21 Mobile1 5w30
325,800 10/24/20
320,500 5/10/19
306,900 7/19/15
296,300 1/10/15
285,300 5/4/14
275,500 11/2/13
265,000 7/7/13
255,000 2/1/13
246,000 9/10/12
237,000 5/5/12
230,000 1/2/12
229,000 12/11/11
222,000 8/15/11
Other Items:
Has roof rack
Has trailer hitch
Maintenance Outline
335,318 3/28/23
bleed brake lines
335,259 2/13/23
Larry’s auto shop
335,000 2/1/23
Mileage: 6/22/22
Larry’s auto shop
Replaced 3 belts.
326,258 1/5/21
Larry's Auto Shop
325,862 10/24/20
325,800 10/23/20
323,000 11/22/2019
System bled and ok
320,497 5/7/2019
BFG KO2’s
265/75/16
Aligned front end
317,000 6/5/16
New battery
309,050 9/10/2015
306,901 7/24/15
300,586 4/14/2015
295,000 1/10/2015
292,734 10/14/14
292,547 10/10/14
291,350 9/24/14
291,002 9/12/14
Adjusted bump stops
290,812 9/8/14
289,000 8/6/14
281,000 2/2/14
Tore down knuckle
New axle seal
2 tubes moly
279,000 1/1/14
265,100 7/5/13
misc small hoses
264,800 6/29/13
Replaced belts
300# torque
replaced fan clutch
255,100 6/10/13
256,000
255,000
255,000 2/1/13
255,000 1/31/13
249,500 11/03/12
drained AT
249,000 10/28/12
exchanged AT fluid
246,000 9/17/12
242,000 7/29/12
237,000 5/5/12
234,000 3/10/12
233,500 3/1/12
Flush radiator
229,000 12/11/11
Replaced starter
Checked NSS
218,700 7/8/11
New battery
325,800 10/24/20
320,500 5/10/19
306,900 7/19/15
296,300 1/10/15
285,300 5/4/14
275,500 11/2/13
265,000 7/7/13
255,000 2/1/13
246,000 9/10/12
237,000 5/5/12
230,000 1/2/12
229,000 12/11/11
222,000 8/15/11
