Arya Ebrahimi said:Since the sliders don't get attached to the body, how do you keep them from flexing up into the body? The ones I built before were attached to the body and were designed to spread the load as such....
Ary
Ary, the outrigger (arms) that hold the slide rail and are bolted to the frame have about an inch of space between the arm and the pinch weld. When you jack the truck up using the slider, they deflect about 3/4 to 1 inch, equating to them just barely missing the weld. I was surprised at how stout the design was. I have noticed the only weak spot, if you want to call it weak, is the arm that goes under the cats. It's longer therefore deflects more. I think if you slammed the truck down on the very front of the cat-side slider it could deflect enough to slightly dent the pinch weld, but not bad at all.
