Hey all. I'm at an impasse with my pig's engine. Here's the latest...but please, don't flame me on the 38. I've seen the hundreds of pages of arguments regarding OEM vs. 38. When I can afford it and they are in stock, I'll snag one of those highly recommended Troll-carbs. Until then, I have to get this figured out with the Weber so I can at least drive the danged thing!
The Weber was brand new in a box with the rig and came with it when I bought it. There was NO carb on the rig at that time. The stock carb was in pieces in a box. After attempting to get that carb rolling, we finally ditched it (for now) and went with the 38 so I could get the dang rig moving. The rig also had a DUI distributor (stock was not with the rig). I've ensured the DUI is installed/aimed properly according to the Toyota 2F engine manual (supposed to point at a particular bolt). There is also no emission device on the truck either. All vacuum ports have been capped, and the only vacuum running right now is the advance from the dizzy to the Weber.
The pig is (I believe) properly timed at this point. Went through the checklist (flywheel BB, TDC, cylinder 1 under pressure, etc). I'm pretty certain (and my well-versed mechanic friend is as well), that we are timed correctly.
When I crank the motor, it won't idle. We can open the throttle up, though, and it will run like a champ. Sounds fantastic actually! No signals of a miss-fire, timing issue, etc. It sounds fantastic...when wide open:/
As we let off the throttle, and the RPMs drop, we've got issues. It flat out won't idle and just dies. I'm pretty certain it's getting too much fuel at the low end. This has been reinforced a couple of times when the motor has started to sputter, and every once in a while (after various adjustment sessions) it will spurt/squirt/shoot fuel out the top of the carburetor.
My thoughts are that it is obviously getting plenty of fuel at WOT, and the timing is in line as it is running clean. My only thought for the idle issue is that it is getting roughly the same amount of fuel at the bottom end as it is when full-throttle, and flooding itself out. With the fuel shooting up like Old Faithful, it appears to me to be a fuel pressure issue (i.e. too much pressure at idle-level throttle and just right when we open it up).
I have both the OEM fuel inlet and outlet lines hooked up to the 38. New fuel filter installed as well. OEM fuel pump is working well.
Could it be an issue with the DUI dizzy not 'talking' to the carb to tell it to let off the amount of fuel going into the carb?
Could it be a lack of a fuel-pressure regulator on the inlet line causing too much psi in the line at idle RPMs? This makes the most logical sense to me, but then again, I'm not extremely well-versed in carburetor/distributor technology.
Or...am I still way out of time? It feels like it should be something remarkably simple that I'm missing here...but obviously I'm lost:/
Thanks all! As usual I really appreciate the time y'all take in answering my NOOBIE questions
