Hi Everyone,
Finally got my 80 series 1HD-FT up and running
however I am having a few issues with the turbo.
Just for some background info... I have fitted a 3" stainless exhaust system including high flow dump pipe, fitted a late model 1FZ airbox with new filter and a large water to air intercooler. The turbo is a Mamba TD05H 16G... I fitted it with the 18psi rated spring in the wastegate (as that is my intended boost pressure) however it seems to make around 10-11psi with an airline directly connected.
I fitted a turbosmart boost controller which i have been able to adjust the pressure up to around 15psi however regardless of how much more i screw the adjuster i can't make more than 15psi boost. So i disconnected the wastegate hose completely and took it for a drive and still only managed to see a peak pressure of 15psi (Maybe 16psi briefly, but settled back to 15psi). This is pretty much from about 2200rpm up to 4000rpm.
I am just wondering if the wastegate is being blown open by manifold pressure and if that's because the wastegate spring just isn't strong enough OR if there's not enough preload?
If the current spring is actually operating around 10psi would using a boost controller be ok for a target of 18psi? Or should I change the wastegate spring to something stiffer (which requires pulling the turbo out and is a pain in the ass job with the other mods I've done). Being a diesel I'm not too worried about boost creep or surges (as the turbo should be capable of running over 24psi while still being pretty efficient).
Cheers,
Cheers,
