vtv to dist. prinary?
Port Townsend, Wa.
My air pump seized. So I gutted it and went forward with a desmog. The schematic { above] shows to remove the vtv to the primaqry vac [ retard?] on the distributer. I am not clear what is meant here. Just take the " blue VtV" out of the vacuum line or block the primary port on the Distributer.:confused:
Remove the VTV from the vac advance hose. Connect vac hose direct to distributor secondary (hi-alt) advance. Primary advance can be connected to air cleaner (atmosphere) or capped.
PS: edit the broken pic link outta your post.
Thanks, Jim. That is what I needed. I will get rid of the link. I have not been able to post the right one. Not for lack of trying.
