VSC OFF, Brake Light & VCS TRAC lights on after rear brake change
Gilbert, AZ
Just changed my rear brakes and rotors. Now Brake Warning Light, VCS OFF & VCS TRAC lights are all on and wont turn off ????????????
Anyone ??????
It could be a wheel sensor wire that broke as they are pretty fragile.
do you hear any noise if you make a hard turn in a parking lot? see if the inside of the rotor hub lip is rubbing against your dust shield. mine did had to remove a little bit of material from the right side rotor hub/lip when i installed a new aftermarket rotor.
