Howdy,
So, I'd been having a problem with my power door locks awhile back, and finally determined my Optima Red Top had seen it's day. After replacing it with a new Red Top, all electrical accesories, including the power door locks, worked like champs.
It's been a few months now since replacing the batt. and I'm back to the same sluggish door locks. However with the engine running at speed, the door locks work great. So, and keep in mind my novice status when it comes to electrical, it would seem that my problem is when the battery is resting/not charging from the alt., right?
I've searched the forums and read alot about making sure all the ground points are clean--which I've checked. And, I've read about the fusible links causing electrical strangeness. My links look okay. I've cleaned 'em and sprayed them with dialectic grease, but I suppose they could be wonky.
So, my question to all you cruiser heads is: what do you think the problem is? Any ideas on where there could be a voltage leak?
As always, any advice/suggestions are great!
Thanks.
Thanks.
