Hey guys,
I've got 193k on the truck. Recently it has started vibrating on acceleration. It almost feels like the tires are dragging something. It also feels like it's coming from the rear. It only happens when it first starts accelerating and goes away at about 15-20 mph. Also, it never happens in reverse. It doesn't happen very often; only about 4 times in the past month and I drive it everyday. Usually, I can make it go away when it does happen by throwing it in reverse and backing it up for a little bit and then throwing it back in drive and driving forward a little bit. After 1 or 2 cycles, it's usually gone. My first guess was a driveshaft issue, probably the u-joints, but I'm not sure and don't know how to check. I also recently greased the shafts but it still happened. If it helps, it has a 2.5" OME lift. Lastly, the brakes recently have been noisy as well if that helps too.
Thanks for any help guys.
