Hi all,
Looking for some advice on identifying bad vibrations in my Bj 73 wagon.
So i recently had my exhaust repaired as it was rattling and came away from the flange mount. Had a flexi fitted and also a bracket to support the pipe on the engine. Pretty happy with the results although the rattling was still an issue. After inspecting underneath i found my transmission mounts were perished. I replaced that by jacking up the transmission and removing the cross member which went very smoothly. Upon starting the engine the vibration that rumbled through the whole car was insane. I then loosened all the bolts and started the engine again to let it settle in. This did help but i am experiencing some bad vibration issues when idle and also under acceleration.
Has anyone had any of the above issues and if so could you share your opinions and advice..
Thanks in advance
Thanks in advance
