I have a quick question about my 76 FJ40. It has started to get a bad vibration in the rear end when I get going over about 40mph. It starts to feel like it does when you have a bad U-joint but I have checked my U-joints and they seem fine. I am pretty sure that it is my pinion bearing that is going bad, because I pulled my drive shaft off the other day and the pinion nut was lose! Does this sound like a pinion bearing to you guys?
If it is the pinion what all is envloved to replace it?
Pull the axles out, pull the 3rd member and pull the pinion out and have the bearing pressed off?
Thanks
Thanks
