Has anyone found the harmonic balancer to be the problem causing a bad vibration?
I have a bad vibration at speeds over 40mph, can't drive over 60. It shakes so bad my carb has vibrated loose twice.
I have been through everything else on the truck.
It started after my H55F install.
I have a new H55F, rebuilt x-fer,new clutch, new u-joints, drive shafts rebalanced, rear axle shafts checked, new 285/75-16 Dueler AT revo's. did it with the old tires as well.
I have gone through everything I know. Possibilities left:
Harmonic balancer
new clutch&pressure plate not balanced
flywheel out of balance after resurface
any possibility of these being the culprit?
thanks for any ideas.
Darryl
Harmonic balancer
Darryl
