I have a vibration at 1500 rpm that feels almost as if is "rotational" and harmonic. While I have a similar vibration at roughly 2500 rpm when the AC is on it is very subtle and not as pronounced as the lower rpm vibration.
The 1500 rpm vibration seems to happen at roughly 30 mph (AC off) and cruising on a straightaway. I don't notice it at all when accelerating or at other speeds or rpms.
The tbelt and water pump, plugs, CV boots/axles have been replaced in the last 2k or less. Same with tires and a fresh FEA. I've also cleaned the MAF and throttle body. Trans fluid has been replaced, so has transfer case fluid.
Could it be the harmonic balancer (would this have been replaced with the tbelt and water pump?) or possibly the bearing in the AC pump, alternator or power steering getting ready to crap out? None of the three are noisy.
It idles smoothly, accelerates well, MPG seems to be within range, and no other issues. 123K miles on the clock.
Sorry for all the details, just wanted to be thorough.
