Ok, so I'm new on here, but I did some searching and couldn't find anything simmilar to this, but maybe I just wasn't using the right keywords.
I have an 87 FJ60 with a Weber carb (not sure what size, previous owner installed it) and cable throttle. Since I bought the truck about a year and a half ago, I've noticed that the gas pedal is harder to press down than I think it probably should be. About 5 months ago it got bad enough that it bent the stock gas pedal to the point where it was useless. I bought a heavy-duty universal gas pedal and fabricated a modified mount to install it figuring the aftermarket carb just required a heavier pull than the stock pedal could handle. It continues to be VERY hard to push the throttle down. I've tried carb cleaner numerous times and also replaced the throttle cable with the Weber part thinking it might be friction between the cable and the cable tube. Nothing seems to make this better. The thing that confuses me the most is that the throttle actuator on the carb can be pushed open with one finger so to me, there is no logical reason for the pedal to be so hard to push. Any ideas? I'm open to any ideas on this one.
