1981 40 2f 168000 miles Runs rough just above idle, and can hear uneven exaust at the tailpipe. Im thinking valve leak
Compression test shows #1=125 #2=125 #3=110 #4=110 #5=115 #6=115
New fuel filter, carb rebuild,plugs,cap,rotor, clutch,brakes etc
lotsa wrenchin!
Adjusted valves the right way with fsm procedure...checked them again...the clearances are good to go
Can I do just the valve job or am I looking at the re-ring as well. How do I know how far to go.
Source for rings/valve parts?
Also need new 3mm silicone vacuum line $or is tooo expensive...where di I find good aftermarket line?
lotsa wrenchin!
