Valve Cover Gaskets and PCV valve parts list (2006 LX470)
Colorado springs
FYI since I couldn't find it here. I'm chasing down an oil leak and plan to replace the valve cover gaskets (along with whatever collateral damage I can replace along the way)
The recommendation is to do spark plug seals and PCV valve at the same time. I found all of the below for ~$170 shipped to me.
Here's my parts list:
Valve cover gaskets (1998-2007)QtyDescription
11213-500311RH OEM cylinder head cover gasket
11214-500111LH Cylender head cover gasket
00295-001031FIPG 103
11193-500108OEM Spark plug tube seals
90109-0616318Valve cover bolts with rubber seals
PCV Valve parts (2006)
12204-500301PCV Valve
12236-500101OEM Valve Cover
12261-500701OEM Ventilation hose
12262-500801OEM Ventialtion hose no 2
90467-150212OEM hose clip
90467-200102OEM hose clip
For other years, cruiserpatch.com (no affiliation) has parts lists here:
Torque spec on the bolts is 53 in-lbs
Will attempt the fix and update if anything was missing.
For anyone else doing this. 54 INCH / lbs. or 5.4 foot/ lbs
Almost screwed this up big time.
  • Like
Reactions: ko2
