Hi all,
Took a little road trip today to look at white 98 LX with 200K miles. Owner wants $10K but seems willing to negotiate. I been looking at LC primarily with less milleage, but thought I should look at LX just to make sure I dont miss anything here (I read the thread comparing value of LC vs LX). Honestly, I am a bit worried buying an LX due to AHC.
I looked at the car and did a quick test drive.
- Interior is pretty clean. Leather is decent shape with some wear and creases. No tear or hole.
- Exterior is pretty clean. Some knicks in paint from road debris. Nothing major.
- Tires seems to be in pretty good shape, lots of thread left.
- No GPS system. Radio works, antenna works, CD player does not work.
- Minimal rust underneath that I can see. Did not see any leaks. Pretty good shape for the age.
- Timing belt and water pump was replaced at 96K miles, so thats due.
- Driver side mirror could not close. The motor was whining loudly trying to close. Can the motor be replaced, or have to buy the whole assembly?
- Front windshield and front passanger side window glass do not have Toyota marking, so those had been replaced.
- Steering wheel do not move forward and back. It will go up and down. I assume the motor is not working.
- Brake pedal was a little weird. The pedal would travel a bit before I can feel the pad starts to bite. Maybe has little air in the system? Owner said brake pads are new.
- AHC seems to work fine, which was really a surprise. It go low, normal, high with a push of a button. I did this several time when parked. On test drive, the car was quite, ride was smooth. AHC fluid is dark. What are the chance that AHC will be working beyond 200K? Or am I buying something that is going to blow up soon? I never driven an LX before so I was impressed with how it rides, and I think my wife is going to like how it rides for her daily drive. I like to keep AHC as long as possible, but unsure how much longer this system can last.
- Anything I miss that I should have look at?
Considering what I mentioned above, some are pretty expensive to fix/replace. What do you think is a fair value for the car? Owner seems willing to negotiate.
Thanks!
Thanks!
