- Year
- 1996
- Vehicle Model
- 80 Series
- Location
- Vacaville, California United States
- Mileage
- 249000
- Color
- rgba(128, 110, 110, 0.98)
Well, the time has come to sell our beloved Land Cruiser. I absolutely love this thing but it’s just not working for our growing family of four. This thing is an absolute billy goat that just goes anywhere you point it and makes it seem effortless. She’s in great shape and I’ve put in a lot of work into keeping her going for many many more years.
Asking 22,000 or best offer.
1996 JZJ80 Land Cruiser with 249,000 miles.
-Triple Locked
-JDM selectable center diff lock button(allowing center diff to be used in 4-high)
-New General Tire ATX in 33’s (Including the spare)
-New power side mirrors
-Gobi Roof Rack with ladder on rear hatch
-100 series brake pad upgrade
-New OEM brake booster, with new check valve and hose
-Diff plug upgrades to Allen key with magnet backing to prolong diff life
-New OEM sun roof rails to keep it functional
-Upgraded to larger G27 Northstar battery
-New OEM Battery retaining bar
-New OEM Distributor
-New OEM distributor cap
-New OEM high tension lines from distributor to spark plugs
-New sparkplugs
-Upgraded Slee Offroad headlight wire harness
-New OEM oil pump seal
-New OEM front main seal
-New OEM Belts
-New OEM EGR valve
-various New OEM water and EVAP hoses
-New OEM oxygen sensors
-New OEM A/C compressor
-New expansion valve
-New OEM Evaporator
-New OEM Condenser
-New air dyer
-New OEM shielded low-side valve tube
-New OEM transmission speed sensor
-New OEM Air Filter (it’s washable and reusable)
-Solve Function LS420 Sun Visor swap
-New OEM window runs for all four doors
-Dynamat and Dynapad on all four doors
-Upgraded front door speakers to Focal 6.5”
-Comes with Ultra Gage
-Wits End Useless Cubby Mount upgrade
-Ram Mount for cell phone and tablet
-Upgraded LED interior and door lights
-Delta Offraod DIY rear storage shelf
-WeatherTech floor mats, front and rear bench
-Third row seat belt delete with Solve Function color match plugs
-New front fender gaskets
-New OEM parking brake boot
-rear mounted fire extinguisher
Also included are all kinds of goodies I haven’t installed or used yet.
-Various new OEM water and vacuum hoses
-OEM Valve Cover gasket kit (comes with valve cover gasket, throttle body gasket, and spark plug gaskets)
-FIP gaskets for both Oil Pan and Transmission Pan
-OEM Oil filters
-OEM fuel filter
The one mechanical issue I haven’t gotten around to fixing yet is a steering gearbox leak. It’s a very slow leak of power steering fluid, but it does actively drip onto ground when it cools down and that O ring shrinks. The plan was to use Redhead Gears to rebuild it with the upgraded 105 series sector shaft.
She has some cosmetic flaws as well. The dash pad is cracked right behind the steering wheel, as well as the driver side door arm pad. The rear bench seats are pretty worn as well with a few spots where the stitching has given up. On the exterior there are chips in the paint from rocks and some tasteful pinstriping. The clear coat has started peeling off the fender flares. Previous owners had some bodywork done due to backing into a light pole and the passenger rear quarter panel paint doesn't quite match.
Let me know what questions you have and any additional pictures you'd like taken.
Call or text me at 707-688-8041
Or email me at jaekin74@gmail.com
Jason
-Triple Locked
-New sparkplugs
-New OEM Belts
-New OEM EGR valve
-New OEM Evaporator
-New OEM Condenser
-New air dyer
-OEM Oil filters
-OEM fuel filter
Jason
