Hi all,
I bought my 4.5 diesel 200 series with a slow starting issue which hasn’t improved with use (car had done very few miles in recent years before my ownership).
Symptoms are:
1. Cranks for a little longer than expected when re-started immediately following shut-down
2. When left 8-24 hours, cranking time ranges from 3-10 seconds!
3. Slight ticking at idle, possibly from an injector
4. Black smoke under acceleration (not extreme but visible in the mirror in some cases)
5. Fuel pressure seems to drop to 50psi almost immediately following shut down and slowly builds up to 4000psi when cranking
Its pretty obvious that there is a leak-back issue in the fuel system and it’s quite possible that some of the symptoms are related to secondary issues.
Warm starting doesn’t make it any worse.
I’d like to do a leak-off test on the injectors but this doesn’t appear to be possible, with the return pipes presumably under the cam covers.
Power delivery and fuel economy are both as expected.
Anything I can do to pin-point a faulty component? My guess is the SCV is responsible for the long cranking (allowing fuel to drain further back to the tank as time passes) and I could also be due an injector or eight!
Many thanks in advance - hopefully there is a knowledgeable Aussie on here!
Symptoms are:
