V. Cover 2F to F
Montana
Well I was doing some winter work on the LC and pulled my v. cover off the 8/74 F and wondered while I take time to clean that up and paint, could I replace it with a 3/76 2F v. cover from a spare engine. It fits prrrrefect, will it work ???? Thanks guys:rolleyes:
Yes it will fit.
You need the seals/cover nuts, etc from the 2F.
The only issue may be the breather to the air cleaner.
Those stamped-steel covers deflect after folks have tightened the cover nuts too much, and then the cover distorts, resulting in an inability to keep a cover seal in place and seal properly.
Really is the only way to cure the cover oil leaks on an F engine. ;)
:meh:
Poser is full of it, as usual.....Here is the real dope....
Yes it will fit.
Don't listen to him.;)
Ed
Thanks guys
Well I figured I would have to play with the air breather to the air filter when I saw it in the back, thanks boys, back out in the shop :)
