I have read the FAQ thread a number of times, but my electrical skills are severely lacking.
I'm missing the OEM fog light harness after the connector that splits off into the separate OEM foglight connectors. What I do have is one end of the connector with 2 red/black power lines (16g) and white/black (14g).
Initially, I was just going to splice/solder the female deutsch connector from the RI wiring harness into the OEM wiring and be happy with the plug and play, but after reading a few comments in the FAQ thread, I'm now wondering how to use the OEM foglight circuit to power the RI harness into running the 20" LED light bar.
How do I wire up the 3 ends (power in, power out, ground) that would normally connect to a switch to the OEM foglight circuit? Or does this require more wiring modification to the harness to make this work?
Here's a pic from the RI website of the harness:
Thanks
*Edit*
Well...I just ended up wiring it directly to the OEM harness. Really like the light output on these. Some things I need to do in the future: 1). Disable the low beam only for the foglight circuit 2). Remount my winch control box so that I can remount the light bar underneath the bumper bar. 3). Buy a Rigid SR amber floodlight for true fogs.
Thanks
*Edit*
