Upper control arms (2 Viewers)
Anyone out there have any tricks on getting the upper control arm bolts out on a 200 series land cruiser?
I assume you mean front?
Basically loosen the nut and unclip everything in the way in front of the bolt as you pull it out all the way to the radiator. I remember having to unclip a harness from a mounting leg on the driver's side, but leaving the battery tray in place. Both sides had a white connector that clipped to the body.. you can get to the tabs for that from the wheel well.
Thanks!!👍🏼And yes the front!
