UPOL'd
Sandy Eggo
So back in aught six I used UPOL spray on bed liner to coat my fender flares and other plastic bits. (thread here). Since my flares apparently did not like my rig (they kept falling off of the trail!??) I decided to remove them permanently. I patched up the holes and matte black sprayed the bodywork and complacently ran around like this for quite awhile.
I finally decided to do something about the 1/2 finished look I was going with and use UPOL to coat the sides. I just happened to have two extra bottles left over from the original spray. My original plan for these 'extra' bottles was to spray the roof, since it had some issues, but chose to cover the rattle can black and badly pinstriped sides instead.
IMO it really cleaned up the look of my rig. I am extremely happy with the way it turned out. I just finished re-attaching the badges, but still need to put the sliders back on.
PICS:
Is that the UPOL Raptor liner? Looks like it turned out nice. I liked the finish of it a lot when I sprayed my trailer with it. But after using the trailer now, I've decided I'm not that happy with the product. It chips far too easily. For what it costs to buy extra and touch it up as often as would be necessary for anything that gets a fair amount of use, it would be worth it to spend the extra $ and just use Linex or other professional bedliner.
Good job though.
Yo Crusher, that looks great. How did u patch up the holes? How did the plastic door trim come off? I'm in the midst of this process, can't decide whether to pay the $$$ for Linex or do the UPOL. Your truck looks great tho... I like the badges.
Sweet. Next you can finish up the rest of the rig. So much better than dealing with paint on a wheeler. :cheers:
Sorry for the delay fellas. I moved and couldn't check back in until now.
Good job though.
Yep, the Raptor stuff. The only place it chipped for me was on the bumperettes (when they were still on the rig). I believe that was due to the bumperettes being flexible. The UPOL is not as flexible as most bedliner products. It is more of a plastic than rubber.
Thanks. I used aluminum tape, JB Weld and body filler to "patch" the holes. This seems to have worked well. Plastic door trim? Most of my flares were torn off on the trail. I didn't have to remove them.
As far as Linex or UPOL; I'm too much of a DIY'er to pay someone else for something I can do. FWIW: I probably would have gone with Durabak if I hadn't already had the UPOL bottles sitting on the shelf.
98 SNAKE EATER said:
Looks great :)
Did you use a sealer before shooting it?
I wouldn't mind doing the same to mine, but I'd need to see how it looks on a white rig first :hhmm:
No sealer, I just really scuffed up the area and sprayed.
ERG80 said:
I like that a lot. Kinda gives it the retro look especially with those emblems.
Thanks. The 40 badges have been on for almost three years now. They get lots of comments.
No kidding. Eventually I'll probably do the whole rig. I was thinking two-tone . . .
That looks great - looks like I've just got the answer to my 'trail de-flared my rig' challenge.
And those Cruiser badges - sweeeeet!:D
GA Trevor said:
Job well done. Interested in what the total cost was.
IIRC it was about $60 for a "kit".
What did you end up doing.
BTW: I just found 4 more bottles of this stuff in my garage.
What to do? :hhmm:
What to do? :hhmm:
Well, it already has the "first glance" appearance of a 55, so you may as well do the roof, as you had planned originally.
Or, keep it until you need to stripe the hood once the paint fades badly.
And as a Durabak guy I would use UPOL because the Durabak is like a stucco wall.
