I am the original owner of 1987 FJ60 64k Miles
Manufactured in Dec. 1986
Recently, I had a full diagnostic evaluation done on my FJ60.
The report came back that for its age my truck was in overall good to great shape.
I have had this truck for almost 20 years and I use it for canoeing, kayaking, fishing ride with my dog type of stuff. I have had it longer than my wife, my house, my dogs and certainly longer than my 3 kids.
I have thought of selling it for 4K to 6K but everytime I really seriously think of what I would use as a alternative exploring vehicle, the only thing that I have considered is something like an Chevy Z71 truck 4x4. I don't mind driving that but it ain't a cruiser.
If I keep it, I want to get it back in great shape, so that it is ready to go for the next 10 to 15 years. I know that if I spend the money I will never be able to recoup if I need to sell. My thinking is to spend the money and enjoy the vehicle.
Would you do it?
Below is a list of upgrades I am considering:
Engine
Recent changeover to Webber 38mm carb., ceramic headers,
desmogged, stainless exhaust, rebuilt OEM Distributor
Front Timing cover - gasket
CoolingSystem
OEM radiator
OEM water pump
OEM thermostat
OEM fan clutch
OEM heater/cooling hoses
OEM cap and a full flush
AC System - convert from R-12 to R-134 system
Electrical System
Battery Cables in poor shape. New custom built cables w/ OEM fusible links. Add relays, a secondary fuse panel,higher output Hella lights.
Drive Line:
Rebuild rear drive shaft - replace both joints & balance shaft
Install H55F OEM new 5 speed tranny, clutch, etc.
Rebuild Transfer case
Axles:
Rebuild existing differentials to 4:11 ratios, installed FT/RR
Change from 3.73 gearing to better run 33" tires.
Brakes:
Replace w/ OEM 4 Runner calipers installed
Stainless steel brake lines installed
Rear brake and emergency brake adj.
Suspension - HFS 3" lift kit from CCOT (This has already been done.)
Exterior
Minor rust on rear frame to be addressed
Full repaint with original color Blue 8B2
Replace all door & window weather strip
New 33" BFG MT & new wheels
Interior
Remove all carpet / prep & Line-X Flooring
Dyanomat soundproofing
Refoam and recover Seats w/ grey marine grade vinyl
Plus other odds & ends.
Would you do it?
Engine
CoolingSystem
OEM radiator
OEM water pump
OEM thermostat
OEM fan clutch
Electrical System
Drive Line:
Axles:
Brakes:
Exterior
Interior
