Jomama
Lucideye
I have done the searches.. It appears the most likely culprit is a sticky caliper piston. I'm just checking to see if anyone thinks I may be missing something...
Late this spring I notice a lot of "brake squeal" while driving down the road.. I heard it most when it could be reflected back at me.. And had a friend stand outside it as i drove around him.. Both of us thought it was a very "typical" brake squeal sound... It disappears when I actually apply brakes. I dont hear it till i start to roll...
Front brakes were given new pads in June 04.
I originally assumed it was one of two things..
1) Rear brakes? (drum brakes on my 93) I was just going to do these preventatively since I'm not sure of the maintenance of these. Parts are on hand.... and my first searches for "brake squeal" suggested that there is a compound in break pads to make them make noise when they get closer to being used up... I thought this might explain the squeal...
2) Brake dust and such on the Front rotors...
Well I finally got to check out my front brakes this weekend... And I was dissappointed to see extremely uneven wear on the pads... Inside pad is damn close to gone, outside pad appears to be about the wear I would expect after 2 yrs (and less than 15K miles).. With the tire off, I spinned the rotor by hand and I do get the rubbing/grinding noise fromt he rotor ...
I did clean the rotor of all the pad dust on it.. but the squeal is still there...
"Uneven brake wear" searches here on mud results in a majority of posts about sticky caliper pistons... And a suggestion or two that a rebuild of these is not really worth it.. and replacement is more cost effective...
Any other thing I should check out before just picking up new front calipers?
Any other general cause for the uneven pad wear??
