ARCHIVE Unbelieveable Pricing on Barnes 4wd Chromoly Heim Joint Kits!
Unbelievable Pricing On Heim Joint Kits from Barnes 4WD!
Our heim joint kits come with everything that you need for one control arm end at an unbelievable price! Each kit comes with one heat treated chromoly heim, jam nut, tube insert and two high misalignment spacers. Check out the prices below, and click on the links for more info. You wont find better prices on a quality rod end anywhere:​
Heat Treated Chromoly 1.25" Rod End Kit - $50.24
Heat Treated Chromoly 7/8" Rod End Kit - $26.74
Heat Treated Chromoly 3/4" Rod End Kit - $21.34
Heat Treated Chromoly 5/8" Rod End Kit - $16.86
We also carry square tube heim joint kits:
Heat Treated Chromoly 1.25" Square Tube Rod End Kit - $55.10
Heat Treated Chromoly 7/8" Square Tube Rod End Kit - $32.92
Heat Treated Chromoly 7/8" Heim Joint Kit for Square Tube
We recently received a huge shipment of a new product we are producing, Heat Treated Chromoly 7/8" Heim Joint Kit for Square Tube. Each of our 7/8 heim joint kits come with everything that you need for one control arm end at an unbelievable price! Each kit comes with one 7/8 heat treated chromoly heim, jam nut, Tube insert for 1.5” ID square tubing and your choice of two high misalignment spacers that will give you a 2" mounting width.
Find all our options on our website: Barnes 4WD Heim Joint Kits
We offer heim joint kits for both round and square tube. Find them all online here. If you have any questions about pricing or availability let us know!
Remember our heim joint kits are complete, so all you need is the correct size tubing and you can build yourself steering or suspension links!
Updated the original post with all the Heim Joint Kits we currently offer. If you have any questions of can't find what you need at Barnes4WD.com let us know. We keep our prices low everyday, and don't mess around with having to enter a "coupon code" to get the best deal on the products you want!
We still have low prices on these high quality joints. We have both square and round tube ends available, find them all here:
Each kit includes:
-1 Heat treated Chromoly Heim
-1 Jam nut
-1 Tube insert (round and square tube available)
-2 High misalignment spacers
Chris May has been using our Chromoly Heim Joints on his 4400 class Ultra 4 car and his other builds over the years with great success. He has also used our tube inserts, misc brackets, tabs and tons of other small parts on this car.
Check out more photos of Chris's rig here: Yota Off-Road Racing
Our Heim Joint Kits are always in stock! If you have any questions about an order, or can't find what you are looking for, let us know. Call us at (828) 551-7616 or email sales@barnes4wd.com with all your questions.
Each kit comes with the following:
  • Heat-treated chromoly Heim joint
  • Weld in tube insert
  • Jam nut
  • 2 High Misalignment Spacers
Heim Joint Installation & Sizing Tips:
  • 3/4” heims: These heims are great for steering and upper links on lighter weight rigs.
  • 7/8” heims: These heims can be used for steering applications with a 3/4” bore. They are also great for upper links on medium to large rigs and can be used as lowers on lightweight rigs.
  • 1 1/4” heims: These are most commonly found on lower links on rigs of all sizes. They’re strong and wear slower than smaller heims due to increased surface area on the liner. They can also be used on upper links, offering much longer service life in that application.
  • When installing a heim joint, it is best to use anti-seize lubricant on both the threads and high misalignment spacers. This will allow for easier maintenance and adjustment down the road.
If you’re looking to swap out your suspension with a link system, check out Barnes’ line of 3 link suspension kits and 4 link suspension kits. You might also be interested in:
