Ultimate T100 OEM parts still available
CA
Maybe this will end up being a short thread. But hopefully some of the experts who have access to Toyota’s systems can help us keep at least some of the few remaining OEM parts for T100s going.
I’ll start off with a rather surprising and definitely T100 specific part… the emblems. 75427-34010.
5VZ-FE 4WD motor mount. Same for both left and right. This I bought in September. Have another on order - dealer says it’s back order but incoming shipments by end of May.
69320-34040. Driver’s side latch assembly for manual locks. Passenger for manual locks is discontinued.
The ones for both sides for power door locks are still available as well.
We all are missing these kick panel screw clips and it took awhile to find them on the diagrams. The 5th Gen Pickup and 2nd Gen 4Runner use them too. Blue and tan are discontinued. Red was never offered in a T100 but surprisingly still is available despite being only on the little trucks from 1989-1991 and very rare.
90467-05051-B0 Grey
90467-05051-D0 Red
T100 V6 fuel filter 23300-62020 is now discontinued. Very surprising as I would imagine they sell quite a few of those. Aside from the bracket, I think the actual filter is the same for for the 5VZ-FE Tacoma/4Runner.
Anyone confirm if this is just on back order or really discontinued?
Those are T-100 specific.
There are 7 in the US. Soon to be 2. :lol:
Tacomas: 23300-62010
4Runner: 23300-62030
I have two and just ordered a third. So one left.
Are you able to check the status of door handles and door latches? Endangered? Low stock?
Speedometer cable for 4WD XtraCab models with Automatic Transmission, 83710-34090.
The one for 4WD manual transmissions is 83710-34080. I believe 3RZ-FE powered T100s use 83710-34050.
The 2WD V6 cables are discontinued it appears.
85212-34012. showing off on this one. These are the factory wipers that would’ve came on the truck new, they can be refilled with the rubber inserts (85214-60020). I have two I bought on Amayama two years ago and now they’re discontinued. The driver and passenger side have different part numbers but they’re identical in length and the same, Toyota just typically puts a different sticker on them and sends it.
The A80 Supra, XV10 Camry, W20 MR2 and a few others all used identical wipers for their passenger side just with different part numbers and all seem to have been discontinued in the last two years. The 1st gen Tundra and a few others use a 19 inch blade like this but have have an ever so slight difference in design and use a slightly thinner insert (Tundra blades are 85222-0C012, 85212-0C012). They’ll work fine but if you’re a stickler like me it’s not the same! I bought some of the MR2 wipers on eBay and will use those and keep these on shelf. I suspect there’s a 19 inch blade identical somewhere in Toyota’s EPC but the part number hasn’t been superseded.
bought mirror glass and cup-holder last year was supersized i could get them.
Confirmed with Amayama that all 3 door latches 69310-34030, 69320-34030, 69320-34040 are still available and able to be procured.
69320-34040 driver side door latch without power locks. Factory fresh! Made May 19, 2025!
