ARCHIVE Ultimate 30 Spline CV Axle Set for Toyota Pickup ('79-'85) & 4Runner ('84-'85)
RCV PERFORMANCE
The Last Axle You'll Ever Need
Loves Park, IL
Website
www.rcvperformance.com
Manufactured in the U.S. using only high-strength chromoly materials, RCV Performance Ultimate 30 spline CV Axle set simply replaces your weak Toyota axle shafts with a new high-strength design. The factory axles were designed with 30 splines at the differential, and neck down to 27 Spline at the CV creating a common failure point. This axle set upgrades the weak 27 splines at the CV to a 300M 30 spline race eliminating the need to neck down the shaft. Tests prove Ultimate CV Axles to be twice as strong as OEM shafts, and they're just as tough at a straight angle as they are at extreme angles. Even if you have big tires and big power there are no worries. Ultimate CV Axles are low maintenance and operate with a smoothness you can feel - whether off road or on the street. And we back it all with a "No Questions Asked" limited lifetime warranty.
Axle set includes right and left inner axle shafts and 2 pregreased CV joints. Black oxide coating is standard, optional nickel plating is available for extra corrosion resistance in salty environments. We can accommodate custom length inner shafts - contact us for details and pricing, or use our Custom Axle Configuration Form.
For a limited time, this kit comes with a free hub gear set!
*Must manually add the item: 4340 Replacement Inner Hub Gear Set
http://www.rcvperformance.com/product-details.aspx?sku=CVJ2851-PU
