this would be a dream -- WITH fender flares --
http://www.toyota.ae/wps/portal/!ut...er Xtreme Edition#Land Cruiser Xtreme Edition
yes again, we get crap here that looks like a 5 year old vehicle, with tinsel stapled to the doors.
Unleash the beast. The Xtreme expands Land Cruiser’s performance horizons with heightened levels of versatility. Teaming up with Icelandic based company Arctic Trucks, Al-Futtaim Motors modified and launched a Special Edition Land Cruiser Xtreme to provide the ultimate off-road experience. As for personality, the Xtreme’s profile clothes its sophisticated power with a neo-sport look, which definitively proclaims its ability to effortlessly overcome any challenge. The result is an intelligently modified Land Cruiser that rules the road with consummate ease and makes for a supremely exciting off-road experience.
1. Fender flares Tailor made fender flares are fitted to cover the large tyres. Made of ABS plastic, the new enlarged fender flares are shaped in vacuum moulds.
2. Large tyres The introduction of large 17 inch wheels and 35 inch tyres provides outstanding off-road performance, and the appearance of floating on the surface when on sand. Cruising on the highway, its elevated position gives best in class panoramic views as you ride.
3. New bump stops Heavy duty bump stops, designed to improve shock absorption when the suspension bottoms out, supplement the strength of the new suspension and ensure a smooth ride in whatever extreme off-road conditions you decide to take your Land Cruiser Xtreme.
4. Side step Thoughtfully extended to match the width of the new fender flare, the modified side step also helps to protect the vehicle body from stones or sand kicked up from the wheels.
5. Strong suspension Xtreme’s suspension has been lifted by 40 mm and the original front and rear shock absorbers replaced by large, specially tuned KONI absorbers to deliver an extreme dampening force. This enables the housing of increased volumes of heat absorbing oil, effectively allowing the Xtreme’s suspension to dependably retain its dampening properties in the most extreme temperatures and endure the toughest terrain off-road and hard driving on-road.
