U.S. Wheel 97 Series Chrome Modular Wheels
I have looked at every possible chrome or shiny wheel for the 85 blue FJ60. I think chrome looks the best on the blue cruiser.
The only chrome wheel I could find with the correct back spacing, lug and bore is the US Wheel 97-7660. Is anyone using these wheels or heard about these wheels?
I am looking for the tall skinny tire setup and am planning to put 235/85r16 tires on these wheels.
U.S. Wheel's 97 series wheels are steel wheels based on the modular design. These wheels feature 10 round holes with a simulated bolt-in center for a 2-piece look. A high-luster chrome finish gives them that show-quality look. They're available in both standard and reverse offset models to fit nearly any combination. Reverse offset wheels have less backspacing and more dish, which may interfere with some brake and wheel opening configurations.
Brand: U.S. Wheel
Manufacturer's Part Number: 97-7660
Part Type: Wheels
Product Line: U.S. Wheel 97 Series Chrome Modular Wheels
Summit Racing Part Number: USW-97-7660
Wheel Diameter: 16 in.
Wheel Width (in): 6.000 in.
Wheel Material: Steel
Primary Wheel Color: Chrome
Wheel Finish: Chrome
Manufacturers Wheel Series: U.S. Wheel 97 Series Modular Wheels Universal
Backspacing (in): 3.500 in.
Offset: 0.00mm
Wheel Construction: 2-piece
Beadlock Functional: No
Beadlock Included: No
Lug Nut Seat Style: Conical seat - 60 degree
Hub Centric: No
Center Bore Diameter (in): 4.280 in.
Center Cap Included: No
Load Rating (lbs): 3,000 lbs.
Valve Stems Included: No
Quantity: Sold individually.
Notes: Modular trailer rim.
Wheel Bolt Pattern: 6 x 5 1/2 in.
Here is the spoke version.
Brand: U.S. Wheel
Manufacturer's Part Number: 75-7660
Part Type: Wheels
Product Line: U.S. Wheel 75 Series Chrome 8-Spoke Wheels
Summit Racing Part Number: USW-75-7660
Manufacturers Wheel Series: U.S. Wheel 75 Series 8-Spoke Wheels
Offset: 0.00mm
Hub Centric: No
Load Rating (lbs): 2,000 lbs.
Spoke version is pretty much the standard for most people, there is also a D-Window version that many people get.
Thing is that the backspacing is not that big of an issue because a lot of people will run small spacers to compensate. I have been wary of the spacer thing however it seems like many people are just fine with them and run 4"+ backspacing wheels.
I am trying to make only functional updates to the FJ60, the PO started to make the FJ60 into a off road beast (ARB bumpers, body armour, OME lift). If I could find 31/9.50r15 tires I would keep the stock wheels.
Thanks for the insights into the spoke wheels.
Now I just need to figure out if I go with 6 or 7 inch wide wheels, then the tire search will begin....
Those wheels belong on a chevy silverado. Or a jeep. Roll with the stock chrome Land Cruiser wheels wrapped in 33x10.50-15 BFG ATs. Classic set up and nothing looks better. Raised White Letter, of course.
I just found this Raceline Rockcrusher wheel.
Brand: Raceline Wheels
Manufacturer's Part Number: 88768060
Part Type: Wheels
Product Line: Raceline Wheels Rockcrusher Polished Wheels
Summit Racing Part Number: RLW-88768060
Wheel Width (in): 8.000 in.
Wheel Material: Aluminum
Primary Wheel Color: Polished
Wheel Finish: Polished
Manufacturers Wheel Series: Raceline Rockcrusher Series
Backspacing (in): 3.625 in.
Offset: -20.00mm
Wheel Construction: 1-piece
Hub Centric: No
Center Bore Diameter (in): 4.250 in.
Center Cap Included: Yes
Load Rating (lbs): 2,500 lbs.
Here is another one
Brand: ION Alloy Wheels
Manufacturer's Part Number: 71-6783
Part Type: Wheels
Product Line: ION Alloy Series 71 Silver Machined Wheels
Summit Racing Part Number: TWG-71-6783
Wheel Width (in): 7.000 in.
Primary Wheel Color: Silver
Wheel Finish: Gloss
Backspacing (in): 3.688 in.
Offset: -8.00mm
Hub Centric: No
Load Rating (lbs): 2,200 lbs.
