The new Lexus which aparantly is based on the 200 series.
I've heard modern diesels described as a turbine with pistons stuck in the middle.
The new commodore with it's 427 cubes will still have less torque than the toureg, rangerover and Q7 diesels.![]()
I dont think torque is the name of the game in this contest,and the figures released so far are for limited output.
Torque may not be the name of the game but plenty of torque is what we all want at low rpm
I was referring to high performance V8s in Commodores
hey rosco, did ya see the 2007 V8 troopie in the Quokka on thursday? $20k, unlicensed and "side" damaged...
nice project for someone with deep pockets!
Ok I haven't seen much discussion here about engine efficiency, so here goes:
Why aren't manufacturers pushing large bore / long stroke low cylinder number engines? !
They will have them in 2 lengths,one on the existing 100 series wheelbase and a 8 seater with a 100 mm extension in the chassis.
Are you sure?
Thats a big change in a car. Like a sedan and a wagon.
If this is true...... the longer wheel base (210srs
) will make a nice duel cab ute.
Why aren't manufacturers pushing large bore / long stroke low cylinder number engines? The less the parts, the less the friction and the better the potential engine efficinecy (maybe not the best for 'sprite' driving, though). Also, the longer the stroke, the better the engine efficiency (to a point, weight and size becoming a limiting factor). Finally, why aren't we seing 30/1, even 40/1 compression ratios? imagine the thermal efficincy that could be attained with such compressions! Of course, we would need ceramic pistons, cylinders and valves, but the efficiency coul be increased to an enormous extent...
Remember the Mitsubishi/Kyocera ceramic diesel of many years ago? I also remember a Porshe experimental diesel that was so efficient, it required no radiator!
