I swaped a solid axle on my 94 truck and after a while the housing is cambering out a bit at the "ball" part of the knuckle. I probably should have welded some gussets in this area when I set up my front end, but I figured if I wasn't launching my truck this wouldn't be a big deal.
The truck doesn't handle bad because of this so far, but it does really wear out the inside of my tires and it looks kind of fallow.
My question to all of you is how to fix this problem. A buddy told me that he welded some gussets in real hot and it actually brought the housing back into alignment. I was thinking that it might be healthier just to straighten the housing cold with a bottle jack, a chain and a peice of railroad iron and then welding the gussets on carefully. Maybe I should scrap the housing and start over again with a fresh one.
Any advice is really apreciated. Thanks!!
