Hmm. Puzzler here. My new'ly turbo'd HJ-60 is exhibiting an erratic stall on deaccelaration. Here's the presentation of symptoms - hopefully somone can advise on an Rx:
- the block is a non-EDIC 2H - key difference here is that the fuel shut-off operates on vacuum, not via the EDIC.
- the turbo is AIT branded, but is a Garrett or Garrett type.
- startup, operation seems normal. Max boost is about 4-6 psi around town.
- where things get strange is when deaccellerating. If I don't apply the clutch, no worries. however, if for example I'm slowing to turn left and switching from 4-3, I get a near stall when the clutch is applied--there is a definite hesitation, RPMs drop below 500, and then come back up when the clutch is let out.
- this behaviour is intermittent. Sometimes (esp at lower speeds <30K) it doesn't show up at all. It's most evident when I'm slowing from 60K to <30K.
Any thoughts?
Any thoughts?
