What do you guys think?
I have a R151F that came behind Toyota Turbo Truck and thinking to swap it into my 99 LC. This are the same manual transmission that came with 4.7 V8 manual tranny LC100. Both use the same transver case as the one we got in US version 100 series.
I did not compare it to supercharger because there is a bolt on kit which makes the swap a lot easier.
I am just thinkering with this to see which one would be more feasible and gives the best performance and driveability onroad/offroad.
Turbo install:
- custom manifold for dual small turbo. One on each side
- Designed for low pressure 5-7 Psi and minimal turbo lag. Possibly T3-T4 hybrid since they are cheap and plentiful.
- Intercooler install (powerstroke intercooler)
- fuel system/management modification (Dastek/Visnu Xede/Unichip)
- Are the tranny need to modied? I know a lot of Tacoma or 4Runner that need transmission upgrade after supercharger install.
Manual transmission swap:
- Need bellhousing from Australia or anywhere else manual transmission are available
- Output shaft (my R151F have 23 spline output shaft, not sure with LC) to connect to the stock transver case or even adapter plate which I am sure could be sourced from Toyota.
- Cluch pedal assy (Australian Junkyard)
- OBDII interface/chip to send dummy message to the ECM? Unknown at this time.
- Might be looking at wiring nightmare since on most modern vehicle the wiring could be completly different between auto and manual and I dont think OBD II are used anywhere else except USA/Canada/Mexico.
Any insight are welcome.
Thanks
Augie
Turbo install:
Thanks
Augie
