sleeoffroad
Supporting Vendor
Look at this for proper placement, I dont think that it gets any more acceptable in terms of protection or ample airflow. HTH.Ohh, if you need more photos of the tubing let me know but it will take little time (weekend) to get to. Again, HTH.
It is a compromise, if you put the intercooler high, then you have to put the tranny cooler below it (like the Safari). If you do the intercooler lower, then you have to do the tranny cooler above it. Pick your poison.
Safari get's away with the inlet and outlet on the PS side since they use a lot of soft hoses that can be shoved into the spots and will also deform slightly.
Avo goes out from the turbo, underneath the motor, the comes out over the frame rail in the DS side More hardpipes with soft couplers.
