I'm about done my 22rte swap, but there are a few things I'm uncertain of.
Does anyone have any pics of the lines that run to the radiator off the turbo? I bought a complete 22rte but never saw it inside the truck, so I'm not sure how the lines are run.
Also, there is an O2 sensor right on the back of the turbo. Can I just use the plug from my current O2 sensor and block the old one off? Could I block the one off on the rear of the turbo and keep my current one plugged in? Will the ECU act up if it is not wired in?
And my last question...
There are two lines that come off the bottom of the turbo. I know one is for oil because it is a banjo line that goes right to the block, but the other is roughly a half inch in diameter and ends at a flange. Is there another piece to attach to the flange that has the banjo fitting on the end to go to the other oil port on the block, or...?
I posted a pic to show what I'm confused about. I circled in blue what I think are the lines for the radiator, and the oil lines in black. Am I correct? You can also see the O2 sensor in the back there where the wire and plug is.
Anything you can tell me would be helpful. Thanks in advance!
