- Location
- United States
1992-1997 production H151 with 1HDT/1HDFT/1FZ input shaft. 14 spline input for standard off the shelf Toyota clutch disks. It has the better synchro set and the 70 series mount on right side for transfer case lever that all cases pre 1992 do not have and some later cases are untapped. Unknown miles. Opened, inspected, and cleaned checking all teeth and forks for wear and any irregularities. I re-FIPG’d the cases together replacing with new OEM the front input seal, rear seal and o ring for oil pump and replaced the reverse thrust washers and bearing and except one of the bolts.
The top plate was a new replacement with new shift seat and is not FIPG’d as the new owner will provide two 10mm pins (pn 90250-10025) and one new bolt (90119-08332) if desired as I was one new one short for reassembly. The top plate will also need a vent bung (90413-06011) pounded in.
No other parts available. Will fit standard h151 bellhousings for whichever model you want to adapt to.
$1,900 Freight included in price in lower 48 states- should ship Fed EX ground. $200 discount ($1,700 total) if picked up in person. I would rather ship vs arraigning mudship as my schedule changes often.
Zelle or paypal with 3% to cover fees and of course cash.
