Hi All,
Recently bought a new to me 1996 Land Cruiser and noticed that it leaks gas when I fill it at the pump. I'm trying to troubleshoot what the root cause / solution might be and was wondering if anyone else has experienced the same issue I am having. I got under the truck to check around the tank and noticed it was coming from the fill line/gasket area and only seems to leak when the truck is specifically being filled. While I am pretty confident this is either down to the fuel fill and breather hose (PO seems to have tried adding more clamps to solve the issue) or the fuel fill gasket, I was wondering if there may be any other sources I could be missing. It also looks like the charcoal canister has been replaced with an aftermarket unit but I have not been able to test it yet. Ive attached some pictures I took where the fuel fill and breather lines meet the tank. The tape on the breather line was also from a hasty "repair" I made when I had filled the truck after I bought it, but I have another picture showing that it also seemed to be leaking out some gas (the main fuel fill area was also leaking like shown in the first 3 pictures during this) which makes me wonder if the tank is breathing properly.
I would appreciate any advice or insight you can offer.
