I need some help trouble shooting a problem. Last May after towing a fully loaded 12ft enclosed Uhaul with the truck loaded down as well from San Francisco to San Diego I started getting a noise when I would pull up to a stop light. The noise was best described as a rotational grinding/whining noise. The noise would only appear every now and then and not consistently. When the noise would start, if I shifted from Drive to Neutral, it would immediately go away. Shift back to drive and it would start up again until I started to drive away. It only happened when stopped at red lights and stop signs with the truck in gear. Based on threads here and another I posted about transmission problems, I got the feeling it may be the torque converter.
I have driven the truck very little since the noise started last May. Fast forward to now. The noise is no longer there. But when in drive at red lights, stop signs, etc. with the truck in gear I get a low rumble/vibration. Shift to neutral/park and it goes away. In neutral/park the rpm's sit around 750. In gear and stopped the RPM's start at around 750 and then drop to about 600 and the low noise rumble starts.
I took it to a highly recommended toyota guy here in San Diego (SD Trux not a dealer) to have him look at it and do a 60K service on it since it was close to 150K now any way. He can reproduce the issue. But in his opinion the TC and transmission are working perfectly. I can partially agree with this as the transmission has always seemed buttery smooth. When he changed the fluids he said it looked perfect as well. No metal, burned smells, etc. He thinks it is something with the modifications on the truck. He thinks the frequency hum/vibration that I am hearing is coming from the Skid plates, suspension, bumpers, something in the mods..... But, basically he doesnt think it is a engine or transmission problem.
Now, had this noise always been just a hum/vibration I might buy into that. But, it started as a rotational grinding noise first. Not only that, I have completely rebuilt the entire suspension since the noise started. I have run around in the truck with out the Skids and the noise is still there. You also only here it inside the truck. Not outside, and nothing in the engine compartment. He did suggest it could be two different issues. Which is a possibility.
The history of MODS:
3 years ago I installed a Slee 2.5" Medium lift and Slee step sliders.
2 years ago I added an 03+ arb and superwinch Ep9
April of this year I added a BOIR rear bumper and Skids
May of this year after towing noise started
August of this year I:
Replaced all sway bar bushings front and rear
replaced the rear UCA's
Installed rear Slee heavy duty LCA's
Changed out rear Springs to 863's
Installed Radflo 2.5 remotes front and rear
Installed Total Chaos UCA's in front
Installed Timbren's front and rear
Installed new sway bar links front and rear
replaced the front diff support that was shown in the 200k refresh thread.
And completely refreshed everything on the underside with new paint and replaced all bolts that were rusted.
So suspension wise, everything is brand new on the underside of the truck. Hell it looks like it just rolled off the show room floor.
So, if I cant find it and the mechanic cant find it..... where would you start? Engine mounts? body mounts? Ideas? Any one had a similar issue?
My biggest fear is to write this off as a harmonic vibration issue and then get way out there and be stranded.
Thanks and sorry for the long post.... just trying to get as much info out as I can....
